Alternative Option to Knife Tool Break Apart for objects with a negative space Needed
 Could "Separate Path" also be used to break apart shapes cut with the knife tool? I was looking in the documentation and it says, "Use the Break Apart command to separate the object into multiple path objects." but what about cases like the image attached where there are negative spaces? I understand I could just click on "Break Apart", but that means multiple steps to re-cut out the negative shapes. I seem to remember there was an issue with this before, I think there was an option to just have the knife to automatically break apart but that caused other issues
 @Boldline I have to check this, but I think separate path should already be used.
 @VectorStyler said in Alternative Option to Knife Tool Break Apart for objects with a negative space Needed: @Boldline I have to check this, but I think separate path should already be used. I had tried "separate path" and for me, it didn't change anything
 @Boldline Can you send me that shape, with the separate path issue? Thanks!
 @VectorStyler I just sent you an email with an example of the issue and a screenshot video as well. Thanks for looking into it further.
 @Boldline Got the file, I will try to replicate this.
