    Did the brush width indicator change? I don't see a difference
    13 Posts 3 Posters 11.9k Views 2 Watching
      @Boldline Those options are for previewing the smoothed brush shape.
      • AyoA Offline
        Ayo @Boldline
        @Boldline see also post:
        https://www.vectorstyler.com/forum/topic/3707/what-does-show-eraser-knife-brush-shape-setting-do
          @Ayo Thanks, that makes more sense now. I agree a little more info would help explain those settings better
          @VectorStyler Where do we switch between the two different modes for the eraser/path brush tool? I'm not seeing the option in the context bar or in the path brush and eraser panels. Thanks
          AyoA BoldlineB 2 Replies Last reply Reply Quote 0
          • AyoA Offline
            Ayo @Boldline
            @Boldline said in Did the brush width indicator change? I don't see a difference:
            More meaningful fewer words
              VectorStyler @Ayo
              @Ayo said in Did the brush width indicator change? I don't see a difference:
              How about "Preview Erased Area" or "Preview Erased Shape" ?
              AyoA 1 Reply Last reply Reply Quote 0
              • AyoA Offline
                Ayo @VectorStyler
                @VectorStyler said in Did the brush width indicator change? I don't see a difference:
                That does not point the user to the 'smoothing' property, that's the core I think. 'Shape' is in VS a too commonly used word in my opinion with many applications/meanings.
                How about "Preview Erased Smoothing" or "Preview Eraser Smoothing"
                1. Show Eraser Shape
                2. Preview Eraser Shape Smoothing
                3. Preview Erased Area
                4. Preview Erased Shape
                5. Preview Erased Smoothing
                6. Preview Eraser Smoothing
                  VectorStyler @Ayo
                  It is not just the smoothing that is previewed, but also the variable with profile (if exists) or pressure.
                  • AyoA Offline
                    Ayo @VectorStyler
                    @VectorStyler Ok.
                    Then "Preview Erased Shape" is now my favourite.
                    Or ...
                    "Preview Erased Shape Properties", but that's again too long and complicated. Then "Preview Erase Properties"?
                    Show Eraser Shape
                    Preview Erased Area
                      Boldline @Boldline
                      Hey @VectorStyler I didn't want this question to get lost in the mix. Where do I go to swap between the two methods of using the path brush and eraser tools? thanks!
                        I understood that this question is about those check boxes. Is it about something else?
                          ok maybe I'm all set - I've updated the build since then and the icon for the path brush and eraser are both the current circle with brush inside and no longer the elongated cross hairs. Maybe I need to play around with it more but the two settings do not seem as different anymore from one another. I will test it more and get back to you
