    Can't move combined selection
    24 Posts 4 Posters 41.6k Views 4 Watching
    • AyoA Offline
      Ayo
      What do I do wrong?
        Subpath @Ayo
        @Ayo
        one cause that came to my mind
        was a reversed direction of a path ?
        or this is just a bug ?
        AyoA 1 Reply Last reply Reply Quote 0
        • AyoA Offline
          Ayo @Subpath
          @Subpath
          Mirrored shapes indeed
          Left shape is counterclockwise
          Right shape is clockwise
          Is that a problem?
            Subpath @Ayo
            @Ayo said in Can't move combined selection:
            @Subpath
            Is that a problem?
            in some cases, e.g blends
            but @VectorStyler will have some deeper knowlede
            I just know that a lot of the problems I had in my last job
            were often due to this. fillings etc. don't work.
            • AyoA Offline
              Ayo @Subpath
              @Subpath
              'Combined' means nothing more than 'two objects selected' (three minus one (square)). No complicated blends or merged situations.
              S b77B 2 Replies Last reply Reply Quote 0
                Subpath @Ayo
                @Subpath
                combined means to me, two or more objects, combined
                via the "combine" option. Left besides the boolean options
                select two objects mean just "select" to me
                • b77B Offline
                  b77 @Ayo
                  @Ayo Works here without issues with the default selection modes: https://recordit.co/jVIoQdCmmp
                  • AyoA Offline
                    Ayo @Subpath
                    @Subpath Sorry!
                    'Two objects selected' than
                    • AyoA Offline
                      Ayo @b77
                      @b77 Exactly what I am doing.
                      Can it be a wrong setting somewhere?
                      Not familiar with 'recordid' but wil try to make a recording as well.
                        Subpath @Ayo
                        @Subpath Sorry!
                        no problem
                        i just saw in your example that your Objects had
                        not the same color, which would be the case if
                        you combine them
                        so i though that you just mean selected, but was unshure
                        • AyoA Offline
                          Ayo @Subpath
                          @Subpath said in Can't move combined selection:
                          not the same color,
                          The gray is intended as the echo or imprint on the burial shroud of the moved item.
                          • b77B Offline
                            b77 @Ayo
                            @Ayo Use RecordIt or some other screen recording app — it's much faster
                            than having to take screenshots, combining them and writing explanatory
                            text over them. 👍
                            And when the file is more complex (not this case here) attach the file as well.
                            • AyoA Offline
                              Ayo @b77
                              @b77 said in Can't move combined selection:
                              text over them.
                              Did my best, downloaded Recordit but my recordings gives grey empty screens.
                              Again something to solve.
                              • b77B Offline
                                b77 @Ayo
                                @Ayo If on Windows: Subpath had only good things to say about ScreenToGif
                                AyoA S 2 Replies Last reply Reply Quote 0
                                • AyoA Offline
                                  Ayo @b77
                                  @b77 On Mac
                                  Didit!
                                  Had to toggle a switch in System Settings, Privacy & Security.
                                  Here my first recording😃 but doesn't solve the problem: https://recordit.co/BbYZq7vnvt
                                    Subpath @b77
                                    can only repeate my praise 🙂
                                    ScreenToGif ( Win only) is a very small screen recorder (only 170 kb)
                                    with features you won't believe, especially at this size
                                    I often use it for longer screen recordings
                                    because Recordit sometimes refuses to upload
                                    Then I play the recording with Screentogif and
                                    use Recordit to record that. Because Recordit stores
                                    the record online, which Screentogif doesn't do
                                      Subpath @Ayo
                                      @Ayo
                                      Here my attemp, work as expected
                                      Win 10, VS 1.2 Beta
                                      Here the Video
                                      • AyoA Offline
                                        Ayo @Subpath
                                        @Subpath @b77
                                        About your recordings: you both can do amazing things that I can't do.
                                        Glad my classic textbook explanation still works. Advantage over Screen Recording is the exercise in VS. Working with, text, arrows etc. (For example, I notice that during my explanation the text cursor in the text boxes does not always want to appear. But that is an other issue.)
                                        • AyoA Offline
                                          Ayo @Ayo
                                          @b77
                                          Not complex, but attach the file anyway.
                                          0_1698330009516_Move2.vstyler
                                          S b77B L 3 Replies Last reply Reply Quote 1
                                            Subpath @Ayo
                                            @Subpath @b77
                                            No problem, explain it with whatever you feel comfortable with
                                            When it comes to screen recording, sometimes it's just easier
                                            to figure out what someone actually does
                                            By the way, I only started screen recording when I started
                                            posting questions about VectorStyler in this forum.
                                            I never needed it before.
