[M1] Problems using the brush, path sketch and pencil tool.
@Kyriakos Thanks for the info.
About the earlier Merge question: that option (checkbox) works with the dynamic mode enabled. In dynamic mode, when the Shift key is held, intersecting sketches can be cut at the intersection points. Merge enables the merging of two open paths at these intersection points.
@vectoradmin Ok i'll have to try that once the other issues are resolved since random things are happening right now and i can't figure out what the correct behaviour is supposed to be, when i hold down Shift either nothing happens, the stroke becomes unselectable or the entire group disappears from canvas.
@Kyriakos Is the Dynamic option checked in the tool bar?
@vectoradmin Yes, and toggling the Merging option doesn't seem to do anything different.
@Kyriakos This is how it supposed to work: https://recordit.co/IAlQsSKWgX
(the Shift key is held, when the red marker is drawn).
@vectoradmin Thanks for that, it's clear now, this seems to be working properly on its own.
@vectoradmin Ok we can scratch one off the list as it was due to my error, i had "Select and transform linked objects or image content of objects" toggled which is why i couldn't reselect the spline.
This post is deleted!
@Kyriakos In the new build: the brush preset selection in the brush tool should be persistent for solid stroke presets also.
@vectoradmin trying it right now, i am seeing two more issues...
Starting from a new document, if i select the brush tool, pick my custom preset from the list and then draw something, the brush will keep resetting to the default one. However if i draw something and then apply the preset it will persist and keep working as expected.
I have my custom preset selected, draw something, deselect the stroke, pick the default stroke and draw again. The new stroke appears as a blend between my custom preset and the default one, as if it's recognising my preset as a profile and not a brush.
@Kyriakos I keep this issue open.
@vectoradmin Both issues are fixed for me in the latest build, the brush selection persists and i no longer get a blend of styles.
There's only one minor visual bug left, that is when you have your custom brush selected and make a new document the old brush thumbnail will persist until you draw something, at which point it fixes itself and defaults to the default one.
