[M1] Problems using the brush, path sketch and pencil tool.
@vectoradmin Ok i'll have to try that once the other issues are resolved since random things are happening right now and i can't figure out what the correct behaviour is supposed to be, when i hold down Shift either nothing happens, the stroke becomes unselectable or the entire group disappears from canvas.
@Kyriakos Is the Dynamic option checked in the tool bar?
@vectoradmin Yes, and toggling the Merging option doesn't seem to do anything different.
@Kyriakos This is how it supposed to work: https://recordit.co/IAlQsSKWgX
(the Shift key is held, when the red marker is drawn).
@vectoradmin Thanks for that, it's clear now, this seems to be working properly on its own.
@vectoradmin Ok we can scratch one off the list as it was due to my error, i had "Select and transform linked objects or image content of objects" toggled which is why i couldn't reselect the spline.
This post is deleted!
@Kyriakos In the new build: the brush preset selection in the brush tool should be persistent for solid stroke presets also.
@vectoradmin trying it right now, i am seeing two more issues...
Starting from a new document, if i select the brush tool, pick my custom preset from the list and then draw something, the brush will keep resetting to the default one. However if i draw something and then apply the preset it will persist and keep working as expected.
I have my custom preset selected, draw something, deselect the stroke, pick the default stroke and draw again. The new stroke appears as a blend between my custom preset and the default one, as if it's recognising my preset as a profile and not a brush.
@Kyriakos I keep this issue open.
@vectoradmin Both issues are fixed for me in the latest build, the brush selection persists and i no longer get a blend of styles.
There's only one minor visual bug left, that is when you have your custom brush selected and make a new document the old brush thumbnail will persist until you draw something, at which point it fixes itself and defaults to the default one.
