Zoom to '100% screen size?
  • Default 100% zoom view is 100% print size view.
    Is it possible in Settings to set the 100% zoom to '100% screen size'?
    Example use: if you take a screenshot and paste it on the artboard at 100% screen size, it retains the same size?
    @Ayo Set the Document Setup -> General -> Resolution to some number (72 for example). And then set the View -> Display -> Display Options -> Display section Resolution field to the same number (here uncheck the Default resolution first).
  • @VectorStyler
    First attempt failed
    Document Setup -> Resolution to 218 (my screen resolution Apple Studio Display)
    View -> Display Resolution to 218
    Result: view much to big
    After calculating and measuring the ruler screenshots I came to a scaling factor of 33%. 0.33•218 Equals 72!
    Second attempt fills the bill
    Document Setup -> No need to change, leave resolution to 300* (default)
    View -> Display Resolution to 72
    *leave resolution to 300
    Better not change, right? Isn't this the resolution for rasterizing effects for HR printwork RIP (Raster Image Processor)?
    0_1698239565150_de4c6af7-49e8-45ed-81ed-40710d571a99-image.png !
