Section 3.9 Path Panel in the manual: Where is the Path Panel?
I feel really dumb asking this in case it is so obvious and/or I find it immediately after porting this question:
Am I missing the Path Panel mentioned in the manual in section 3.9?
The manual mentions selecting it using the Panels - Path command that I am assuming is under the main menu's Panels entry. I could not find anything similar. Was it perhaps renamed, and/or moved to a place where I can't find it?
Thank you in advance.
This post is deleted!
Thank you. I also posted in the bugs forum. The panel is not there. I looked at a YouTube video where the Path menu entry was present in an older VS release (https://www.youtube.com/watch?v=Q9zlKgjtY4o at 2:50), but it is now missing in my installation (1.1.100, macOS ARM). Turns out it can still be accessed using the option-P shortcut key. I also noticed that the panel names in the menu and inspector panel names that are opened are mismatched.
@_NM_ See answer to the opther post, something broke in the update.
@VectorStyler Thank you. I responded in the Bugs forum. Resetting, reinstalling, ... nothing worked. Unfortunately, the application is no longer usable. The entire menu Panels menu structure is misbehaving.
@_NM_ Did you try removing the ~/Library/Application Support/NumericPath/VectorStyler1.0 folder?
Thank you, how did I miss that folder? Return of sanity! Before that, almost every menu item was doing something unexpected. Reminds me of where I work
@_NM_ This is a bug in VectorStyler that I could not replicate it yet here.
Somehow the old resources (text in this case) end up in the user folder (probably) and the new version after updating ends up using the old resources.
