Cannot use any other color mode other than RGB.
I was playing around in VS causing nothing but trouble. After awhile something happened and the program came to the point where I was no longer able to switch to any other color mode but RGB.
I was already trying to repro a crash when this happened and decided to stop the video and show it. I am not sure what exactly caused this and why but you can see on the video when I select a shape and switch to HSB color mode, as soon as I click on one of the HSB sliders and try moving it the mode immediately jumps back to RGB mode.
Forward to 2:00 minutes to see it.
https://www.youtube.com/watch?v=ssVCUAbxT1ESettings and Workspace files:
https://www.dropbox.com/scl/fi/k0y8apnhhw1kwhmkuo63v/VS-settings-workspace-202308030132.zip?rlkey=aq0ahrhowh9dsbhi1ymttci0t&dl=0VS 1.1.095
It was something with the workspace and/or settings file. Once I removed both, the sliders are working ok. Will try to break it again... won't give up
@pentool Added this to the backlog, I will try to replicate it using the workspace and settings files
@pentool Replicated the bug here also, the fix will be in the next build.
