    Attempting to change the number of blended objects causes number to change independently
    7 Posts 2 Posters 7.9k Views 1 Watching
      When using the blend panel, if I use the mouse to select all the digits in the number of blend objects, it goes wonky most of the time
      Here is a video of this happening
        @Boldline Is this cause by using mouse scrolling on the number field?
        BoldlineB 2 Replies Last reply Reply Quote 0
          @VectorStyler said in Attempting to change the number of blended objects causes number to change independently:
          Yes it is happening when I am using the mouse
            @VectorStyler The issue seems to happen in any text input field, not just the blend
              @Boldline said in Attempting to change the number of blended objects causes number to change independently:
              Yes, it might be in fields with integer numbers.
                @VectorStyler This issue is still occurring for me in Build 93. You may very well still be working on fixing this, but I wanted to bring it up just in case
                  @Boldline Should have been fixed (tested here). I will reopen this bug.
