Text distortion: adding a stroke (after)--> changes the text size
I've applied deformations to text without a stroke and adding a stroke afterwards changes the size of the text.
If this is unavoidable, it is a good idea to remember to finalise the text before distortion:
@Pat Are these deformations Image Effects or Shape Effects?
In this case Shape Effect is better. -
@VectorStyler I guess this is shape effects (through the distorsion tool):
@Pat Not sure from the image, but the tools only create shape effects.
These should be listed in the Shape Effects panel. -
@Pat Send me the two examples of the first post. Not clear what could cause this.
@VectorStyler File sent
@VectorStyler the issue is (at least) tied to 'transform':
@Pat said in Text distortion: adding a stroke (after)--> changes the text size:
Added this to the backlog as a bug.
@VectorStyler I'll send you this file again asap. The fill colour of one of the contour object can not be changed.
