3D Help
  • @Igull said in 3D Help:
    @Subpath said in 3D Help:
    Another strange Solution
    Yes, I suppose I could do that too, but I have a Fusion 360 and an Onshape licence which can do pretty much anything in 3D - I was just looking for an easy way out with a 'one trick pony':-)
    Neil
    Understandable 🙂
    But its a bit harder for Mac User.
    On PC there are a few more Options
    Here a Extrusion from Magix Graphics Designer
    which also has such a Tool build in (PC only)
  • @Subpath said in 3D Help:
    You're rubbing my nose in it 🙂 🙂 🙂
  • This is not directly related, but I've been giving thought over time to how to best create the 3D wrap around look with a vector path. I was thinking of it in terms of a dedicated shape like the existing oval and rectangle shapes, but now I'm thinking the best way to create those will be when basic 3D extrude is (hopefully) added to VS
    0_1685975559387_5932f189-cd44-4ee0-8eac-3fb7d41d5356-BLD 2023-06-05 at 10.24.01@2x.png
    I probably should not have done that 🙂
  • @Boldline
    In Corel you could take any Form/ Shape
    (even grouped) and extrude it
    in Magix Graphics Designer too
    The result in Magix is only a Bitmap
    but it has more lightning, beveling options
    In Corel it stay as a Vector Object where you could
    break apart the parts and reuse them as vector objects
  • Global Moderator
    @Igull not sure about the demo version, but I have a paid license of Art Text 4, and I can just drag a PDF exported from VS into the Art Text window and it loads it as a 2D shape.
    I can then right-click and convert to 3D after which an option to set the extrusion depth becomes available in the properties area on the right.
  • @fde101 said in 3D Help:
    Mmm, tried a number of PDFs all of which dragged across, but didn't show on the artboard (or only showed the bounding box - and you couldn't right click to create 3d)- seems extremely slow and very unstable (tried it on an M2 this afternoon - a bit faster, but same results) - may be something to do with the demo version. But all it has is a TRIAL watermark, everything else is supposed to work according to the info. It's probably fine for doing text and minimal 3D objects I think - might be too much heavy lifting to move all my bits around.
    Thanks for the info, I'll keep the trial, might find other uses for it !
    Neil
