Default palette seems to be missing reg black and "no color" swatches
I noticed because I was not using a custom palette as my default, that the current default palette in VS seems to be missing the "no color" and the reg black swatches. could those be added back in?
dont know if we mean the same thing
but for me everthing is fine here
@Subpath ok that's good - I wonder what the issue is here. I'll play around with it a little more and see if I can refresh things and get it to fix itself.
If I open up the default "color palette" it is showing correctly. Maybe I had something else opening as "palette" that was missing those options
@Boldline said in Default palette seems to be missing reg black and "no color" swatches:
The "Palette" mode shows the current document palette, not the default palette.
You have to create a new document with a Default RGB/CMYK palette to show the actual default.
