    Eraser and Knife Tool bugs.
    16 Posts 5 Posters 13.3k Views 5 Watching
    • encartE Online
      encart
      Since the release of the last two builds, the Eraser and Knife Tool have returned unpredictable results for me.
      https://recordit.co/rf3VE9zrPy
      S VectorStylerV 2 Replies Last reply Reply Quote 0
        Subpath @encart
        @encart
        it looks like it looses combining when using eraser
        combining it again fix it in my tries
          VectorStyler @encart
          @encart Disable the "Separate Path with Knife Tool" (and Eraser Tool) option in Preferences -> Editing Options 2 (bottom left checkboxes).
          • IgullI Offline
            Igull
            Sadly I'm also getting changed results with the eraser tool 😞
            Previously, you didn't need to select the object that you wished to erase a part from - now you do and it just adds another level of work.
            You could just work your way through all the objects without selecting anything - this is with the 'separate path with eraser tool' option selected of course.
            This is one of the most important tools for me.
            Neil
              VectorStyler @Igull
              @Igull What is selected when the eraser tool is activated?
              If no object is selected, then the eraser tool should work on all objects.
              IgullI 1 Reply Last reply Reply Quote 0
              • IgullI Offline
                Igull @VectorStyler
                @VectorStyler said in Eraser and Knife Tool bugs.:
                With no objects selected, the eraser tool works ok on the first object and any other part of the first object. However, when moving to the next object, the first object remains selected and you can't erase any part of the next (unselected) object.
                Previously, it didn't matter, you could continue to any object without selecting it. I think I actually mentioned that this was a feature that I really liked with eraser tool 🙂
                Neil
                  VectorStyler @Igull
                  @Igull Seems to be working here for other objects also (not just the first, where the eraser was used).
                  In the context panel, there is a "Source" drop down, try selecting a different option.
                  IgullI 2 Replies Last reply Reply Quote 0
                  • IgullI Offline
                    Igull @VectorStyler
                    Mmm, still not working, tried a fresh file and changing the source selection/layer/canvas ?
                    Neil
                    PS, I'll reboot VS and see if that matters.
                    • IgullI Offline
                      Igull @VectorStyler
                      Just tried rebooting VS with a new file, same issue, first object ok - successive objects no. Source makes no difference either.
                      Neil
                      • IgullI Offline
                        Igull @Igull
                        @Igull
                        Seems that if an object is selected, then the eraser tool won't work on subsequent (unselected) objects. The eraser tool automatically selects the first object when you attempt to erase of course 🙂
                        It works ok (on the next object) if you deselect the first object.
                        Neil
                        • b77B Offline
                          b77 @Igull
                          @Igull Same here: https://recordit.co/6p6vInXuJk
                          The workaround is to press the Escape key, which deselects
                          the current object and lets you "jump" to any other.
                            VectorStyler @Igull
                            @Igull I will have to replicate this somehow.
                            • IgullI Offline
                              Igull @b77
                              @b77
                              Yes, I've been using the escape key 🙂
                              Neil
                                Subpath
                                @Igull , @b77
                                Perhaps a "select all" or select all parts that should
                                be edited with the Eraser might be helpful
                                Here a Video
                                • IgullI Offline
                                  Igull @Subpath
                                  @Subpath said in Eraser and Knife Tool bugs.:
                                  I don't see the point in that, it's just more work ? Selecting all can lead to other unintentional bad things happening 🙂
                                  Selecting the parts that you need to erase is yet another minefield of work 🙂
                                  Why not just have it work correctly - pick erase tool - erase part - simples - that's how the thing on the end of your pencil works 🙂
                                  A 'workaround' would be to have VS automatically deselect after each erase operation - then the problem would simply disappear 🙂
                                  Neil
                                    Subpath @Igull
                                    @Igull
                                    was just a though of mine 🙂
                                    i think i often have lesser Objects to handle
