How to apply effects to other objects?
@Pat Is the offset created with the "Object -> Shape -> Offset Path" or with the "Effects -> Outline -> Offset Path" ?
Only these have a "preview"
@VectorStyler Object -> Shape -> Offset Path
@Pat What values are in the "Distance" and "Steps" field?
@VectorStyler close to this:
@Pat Still no luck. I will try it again tomorrow.
@Pat said in How to apply effects to other objects?:
I think there is still enough space to get sharp pointed edges but no way by modulating the miter limit... another way ?
The blunt corners are caused by open paths. At the highlighted locations, the nodes overlap, but the paths are actually open. Use the Node tool and the command in the context panel to connect the nodes.
