Editing the Clipping Mask
@William-Kansepa The clipping shape of a group can be edited with the node tool, and if the nodes are selected, the transform tool can scale / rotate that.
Another way is to use a separate object for the shape only. Set a name for the object and enable the Shape object role (Object Options view)
Then select the shape from the Styles field of the Shape panel as a clipping shape of the group.Editing the shape of the original object will propagate to the group as a clpiping shape.
@Subpath said in Editing the Clipping Mask:
something like this is also possible
but moving, scaling only when the Clipping Shape
is converted to curve@Subpath Thank you. I am aware of this workaround method of first converting the mask to curves, but I was thinking more of an easier, practical and efficient way...
Check out the way it's done in other competitor software:Affinity: (Lock Children)
Xara Designer: Right+Click on clipping mask and you have options to Open Clipped Group, Select Clipping Shape, or Select Clipped Objects
Coreldraw: Lock or Unlock Powerclip Mask
Adobe Illustrator: Click on edge of the mask with Direct Selection Tool and use the Selection Tool to scale or rotate. Use Shear or rotate in the Transform panel etc...
I will try it out
I have the first three appswell, I don't really have any big problems
with the way VS does it
I will try it out
with the way VS does itPlease do that. Point of note: in all programs I have mentioned, you don't necessarily have to convert to curves the clipping mask.
Tried the clipping Mask/Shape Editing in the other programs in the meantime
Found Affinity Designer the easiest and most clearly arranged
Will make videos about how all three work
@Subpath Thank you so much for your tireless efforts and commitment in making VS greater.
gladly
Well, I think VS is a program with a great potential ( love the Features)
and I'm happy to support the developer ( which I admire a lot ).
@William-Kansepa
@VectorStylerBasically I don't have a big problem with the clipping mask/shape handling in VS
if you want to transform the clipping shape separately from the content.But i have to admit that it is not such an ideal solution that you have to transform
the clipping shape into curves first. And thus a Parametric Shape is lost.It would be more ideal if you could do this without converting to curves.
Here is a Video of how 3 other Programs do it.
I show the programs in this order:
Affinity Designer, Xara and CorelDraw
In all three you don't have to convert the shape to curves first.
@Subpath Disabling 'Transform Content' from the app's context menu should do this locking of the objects inside containers.
(But it shouldn't be disabled by default).
@Subpath It doesn't at this time, but I suggested in the other thread that it should work for clipping containers.
@b77 said in Editing the Clipping Mask:
ah, ok
have read your post about it
