    Dragging a file from file explorer right onto the canvas.
    6 Posts 3 Posters 5.2k Views 3 Watching
    • encartE Offline
      encart
      I don't know if this possibility exists in Win10 and is just a bug, or if there is no such possibility.
      Currently, in my case, importing an svg file is possible only via Import dialog window.
      This is how it works in Affinity:
      alt text
      VectorStylerV S 2 Replies Last reply Reply Quote 0
        VectorStyler @encart
        @encart Drag&drop from explorer works here (from the regular file list).
        What is the shortcut for that kind of search box on Windows?
          Subpath @encart
          @encart
          can confirm that Drag and Drop works
          tried ist also from desktop, any folder
          and from my search Program "Agent Ransack"
          all works
          • encartE Offline
            encart @VectorStyler
            @VectorStyler said in Dragging a file from file explorer right onto the canvas.:
            I'm using an app called Listary (https://www.listary.com/)
            This search box appears every time I press Ctrl twice.
              @encart Does drag&drop work if done from the regular file explorer app?
              • encartE Offline
                @VectorStyler I can not explain how, but it works now. From search bar and file explorer as well. I didn't restart the app. VS was running in background. Since I remember I have random problems with opening files assigned to VS from file explorer, SVG's for example. I coudn't find any sequence yet. Do you have any ideas what should I do to get closer to solving the problem when it arises?
