Selection mode depends on the direction
I found an interesting fact in Rhino 7 today.
Depending on the direction of the selection, you can select all objects touched by the selection or only those inside.
https://recordit.co/wvedmEz0Gr
interesting, but I find it a bit curious
that in both cases a selection box is used.In the second case, in my opinion
a simple line would be totally sufficientEdited:
ok take it back a little
if you have many small objects
a selections box will make sense
