Draw tool sticky settings?
  • @Ingolf
    Everyone should be encouraged to share their ideas freely and any dissenting views should be respectful. One of the best aspects of VS and the forum is that ideas are encouraged and solicited and then are often added and tested. If they don't work well, they eventually get removed or modified until they do.
    For example, none of this would be located here if I had my way - but for you and maybe others, this was something that was requested - so it got added and is being tested. There's a give and take.
    0_1658501208342_bec465cf-e7c2-4d68-9988-2ad98fb15cf0-BLD 2022-07-22 at 10.45.02.png
    @Ingolf said in Draw tool sticky settings?:
    Yes much of the user interface is confusing because there are way too many options everywhere. Complexity. And looking at much of it I know it will almost never be used. But we will all see it in the interface.
    The context panels are filled to the brim, and so the question is whether in the future you expect trial users or new customers to remove all the superfluous features, or think "this is too much for me" before it occurs to them. It would be more than naive to imagine thousands of new customers happily finding and using the opt-out. Not gonna happen.
    And a context panel simply needs to be ultra-focused - not more chaos.
    You have offered many great suggestions and found many bugs over the years and those are appreciated. You have also preached about simplicity and avoiding chaos in the UI while being the major voice behind adding a ton of symbols and icons to the UI to avoid keyboard shortcuts. I don't see how one can request a more simplistic UI while at the same time asking for more and more icons and symbols that will inevitably cause the new user more confusion and look more overwhelming.
    The fact that the developer is very involved and very responsive and willing to try new radical ideas to see a better VS result is a special thing. Contrast this with Illustrator or with Affinity, who do not engage their user base often and prefer to trust only a small handful of people. We don't always get what we want in VS, but we have the flexibility to try things and remove things (via the developer) and to see what works best... that is a major advantage over the competition
    For what I see, in these discussions, the pencil as a brush is not a good way to go. Luckily this is still optional, and basically has no impact on the code.
    The Pen using a brush would be an option (if enabled in preferences). Here, the question is that if the last selection was a brush then what would the Pen tool do (again if the option is enabled)?
    I think the default (and preferred) mode of functioning should be what already exists in other apps.
    Anything else should be accessible (if supported) through options.
  • @VectorStyler said in Draw tool sticky settings?:
    In my Opinion:
    If the Option for "Vector Brushes" is activated for the Pen Tool
    it should stay with Vector Brushes.
    (e.g. the last ones used).
    If this option is disabled, it should work as usual.
  • @Subpath said in Draw tool sticky settings?:
    Yes please ------ for me that would be a great solution when working on jobs similar to the examples shown earlier in the post.
  • @VectorStyler The idea was to have a visible checkbox (no Prefs involved) that locks the contour type
    so that if you enable it and switch from the Brush to the Pen tool, the Pen tool continues with
    the same contour.
    @Ingolf argues that this Lock/Sync checkbox should be placed in the Brush panel (to avoid cramming
    the context bar), while me, myself and I don't mind it being visible and easily accessible in the
    context bar (preferably after the Line/Brush dropdown).
    Maybe he's right, or maybe being visible helps less experienced users figure out faster
    what happened to the Pen tool if they forgot they clicked it.
    But I think both of us agree that having this as an option in Preferences is not practical — you need this
    sometimes to enable it quickly, not to go to the Prefs to find it.
  • @b77 said in Draw tool sticky settings?:
    Damn right.
  • would also plead for a way
    where this option can be switched on and off
    in a quickly accessible way
    e.g. Brush panel or something similar
