    Is there an option to limit either the width and/or length of the shape tool?
    9 Posts 3 Posters 7.2k Views 2 Watching
      Is there or can there be an option added to the shape tool - for example, the rectangle tool, to allow it to be limited to a predefined height or width or both?
      In a similar way with stars and ovals?
      • b77B Offline
        b77 @Boldline
        @Boldline By that you mean an aspect ratio "lock" (golden ratio maybe?) that allows for different sized shapes, or an actual "locked" width or height for the shapes?
          Boldline @b77
          @b77 actual "locked" width or height
            If it's not already in there, what about an option to set an angle and everything made is set to that angle?
            • b77B Offline
              b77 @Boldline
              @Boldline I don't think it's possible at this time.
              Can you explain a bit the context?
              • b77B Offline
                b77 @Boldline
                This is different from your first request (if I understand correctly), and I think you can simply rotate the canvas at the angle you need (see the second field at the bottom of the document window) and everything you draw will be at that angle until you rotate it back to 0°.
                  Boldline @b77
                  @b77 yes I probably should have made it a new thread
                    @Boldline said in Is there an option to limit either the width and/or length of the shape tool?:
                    No such option. Only proportional, or centered drawing.
                      This one actually can be done by rotating the view. The rectangle (or oval) drawn will use the view angle.
