Was the shortcut to click on a file name tab to see it file location removed?
I remember a while back we discussed adding the option to find the source location of an opened file in VS by clicking on the file name tab with a modifier key and it would show the file in it's location. I know that got added because I frequently used it. Was that removed?
@Boldline On Mac: Option+ click on the document title tab.
@VectorStyler ok I had initially tried that without success. Then later VS crashed and now that it's open again, the Option+ click works again. thanks
UPDATE: Does this feature only work with native VS files? Because I can successfully do that with VS files, but an Illustrator file will not work
@Boldline It is not working with AI files. Will fix that.
@VectorStyler It does not seem to work for eps or pdf files either....
Why option instead of command, which is the standard key for doing that?
@fde101 said in Was the shortcut to click on a file name tab to see it file location removed?:
I will verify if it is in conflict with something else, and change it to Command if not.
Also: it will be configurable.
@VectorStyler I tried it but I could not see the file location.
@Jayanta-Das I check what happens on Windows. Normally, it should open the file Explorer and highlight the file.
