Show, Find and Replace Color option in VS
This idea is already listed in the roadmap in part : "Search, match and replace color using a color palette" It may be assumed, but just to be sure, I'd like to be able to have VS tell me all colors currently in use on the artboard with an alternative option to only show me all colors used on a particular layer.
When I have a design I'm prepping for output, I'm not always printing it, and while I could go into the print settings and see colors, it would be helpful to be able to click an option and see them listed out so I can easily know if that layer or artboard has two similar colors I'm mistaking as one.
This would easily tie in with the "Search, match and replace color using a color palette"
@Boldline What you describe should happen in the Color Palette panel? Like this?
@Boldline @b77 yes, something along these lines. The exact use cases and UI is not yet clarified so input is welcome.
