    How to get a repetition of shapes with a displacement and a rotation ?
    12 Posts 4 Posters 14.4k Views 3 Watching
    • B Offline
      B-Vs-V
      Hi,
      I can do such scheme in a couple of minutes in AD (Ctrl + J)
      but it is more tedious in VS:
      • first, Ctrl+J doesn't replicate the object, and
      • then, I get this
        or nothing
        or this
      and finally, with the rotation center at the right position and Ctrl+D
      Would it be possible to get it as easier than in AD ? A displacement, a rotation and Ctrl + "whatever" to get the job done ? or to get this with the recent action panel ?
      thanks
      S VectorStylerV 2 Replies Last reply Reply Quote 0
      • S Online
        Subpath @B-Vs-V
        @PatrickM
        just two thoughs
        couldnt this help you ?
        Menu > Object > Transform > Rotate
        and then choose "copy" in the dropdown menu
        an other way could may be a Blend
        and to bring the Blend Panel up
        Panels > Effects > Blend
        there is an option to make a blend to a path/curve
        and try it this way
          VectorStyler @B-Vs-V
          @PatrickM Something similar in VS:
          • with the original object selected:
          • adjust the rotation pivot.
          • move with Alt+ to duplicate first.
          • rotate by some angle.
          • Control+D to duplicate and move.
          Not sure if you get the same effect as in AD.
          Another way (1) with align to path:
          • create a number of ellipses, position or rotation not important.
          • draw a path that has the shape needed (for example the red on the right bends leftward).
          • select the ellipses and then select the new path.
          • in the Alignment panel click on the first Align to Shape icon (first make sure that Rotate Objects is checked)
          Another way (2) with scatter brush:
          • create one ellipse, keep it selected.
          • open the Brushes panel.
          • create a new scatter brush style: "Create Scatter Brush Style" in the panel menu.
          • set the name of the brush in the Name field.
          • set the spacing to 60% (or some number for the spacing between ellipses).
          • confirm the scatter brush creation.
          • draw an open path along which the ellipses are placed.
          • apply the newly created scatter brush style (should be second in the list).
          • set the brush width to a suitable value.
          • or check proportional to keep the original ellipse size.
          In this case the path can be adjusted dynamically and the ellipse positions, rotations (and their number) is automatically updated.
          • B Offline
            B-Vs-V
            @Subpath thanks for the tips... blending can be a way indeed, I didn't think of it since it is lacking in AD that I use for a couple of years for my lectures diagrams.
            @vectoradmin thanks too for these useful informations. I will try all these (also blending) asap to get used to other workflows.
            Thanks ☺ 👍
            • B Offline
              B-Vs-V
              @vectoradmin I know that there are already video tutorials for some VS features and I know that you are extremely busy working on VS but I think it would be nice (important) to develop this aspect of educational training for beginners & intermediate users to illustrate and highlight all VS functions/features. I don't always want to compare with other companies but some have been quick to make this available and it has certainly increased the interest in using their software IMHO. I personally find the videos very helpful in learning how to use software.
              VectorStylerV S 2 Replies Last reply Reply Quote 0
                @PatrickM said in How to get a repetition of shapes with a displacement and a rotation ?:
                yes, this is very much needed, and I will try to reserve more time for this.
                • S Online
                  Subpath @B-Vs-V
                  @PatrickM
                  " video tutorials for some VS features.... "
                  Well, we users can also do something 🙂
                  Already thought about a small series in tutorials
                  where I show some things that might not be soo
                  well known. Where anybody could also contribute
                  his own tips.
                  @Boldline also thought about publishing his tips.
                    Boldline @Subpath
                    @Subpath Yes, I've been trying to decide the best approach - if it should be a videos for individual functions or groups of functions at a time. I don't want them to be too short or too long.
                    • S Online
                      Subpath @Boldline
                      @Boldline
                      I don't know if all this can always be regulated so precisely
                      and I wouldn't regulate it too much, but I try to keep
                      Videos and Picture Explanations for Tips rather short.
                      Everything else I would rather see as a Tutorial.
                      • S Online
                        Subpath
                        @PatrickM
                        Here a Video how Blend on Curve works.
                        The Circles are already blended.
                        (you could edit the steps with the Up/Down Arrow Keys
                        by clicking in the Value field)
                        Here the Video
                        Blend on Curves
                        Found yet another function of Blend on Curves
                        Blend on Curves 2
                        B 1 Reply Last reply Reply Quote 2
                        • B Offline
                          B-Vs-V @Subpath
                          @Subpath said in How to get a repetition of shapes with a displacement and a rotation ?:
                          @PatrickM
                          @Subpath Amazing, thank you for your time ! 👍 ☺
                          • S Online
                            Subpath @B-Vs-V
                            @PatrickM
                            Things seem to be a bit easier than I thought after all.
                            As I found out in the meantime, every Blend is is already
                            on Curve/Path
                            , dont know this before. All you have to do is
                            select the blended shapes and switch to the "Shape Editor Tool"
                            and you can bend your curve.
                            Blend to Curve 3
