Brush and Pressure
https://recordit.co/cvRkhejmTQ
@vectoradmin Here is the recording that may help you. -
@Jayanta-Das Replicated. The stroke profile seems to be wrong.
Select the solid Profile the Stroke panel. -
@vectoradmin Stroke profile revert to none after painting with the brush.
@vectoradmin With the latest update I can paint with Pressure ON and I can change stroke also but still Brush Pressure not working.
@Jayanta-Das Are you using the Brush Pressure with a tablet?
There is an open issue that with some tablets, pressure is not detected on Windows 11.
@vectoradmin Yes.
