    File drag and drop not working on windows 10
    13 Posts 2 Posters 12.5k Views 2 Watching
    • F Offline
      freggern
      • When no document is opened, drag and drop only will work if you realeased it in the middle area of the document area. There is a big spacing around this area without doing anything
      • When I drag and drop it to the tabs of the opened documents it don't will add the file as a new document or do anything.
        VectorStyler @freggern
        @freggern Yes it can be replicated, it seems that there is some issue with the margin (only a narrow margin at the bottom for me).
        I will keep this open.
          @freggern This problem should be fixed now.
          • F Offline
            freggern
            The last two bugs where fixed before. I think there is a regression in this build you can't add Layers over the drag and drop function by using the layer panel. It will open a new document. I think in last releases it added a new layer with the svg file I dropped there.
              @freggern I will try to replicate this on Windows.
                @freggern I could not replicate this on Windows: if I drag a file over an open document canvas area, it will import the file content as a new object into the document.
                • F Offline
                  freggern
                  I dont mean drop it at the document canvas area. I mean dropping it direct on the "layer panal"-area when a document is opened.
                    @freggern said in File drag and drop not working on windows 10:
                    Now I got it. Dropping files into the Layers panel is not yet supported (neither on Windows or Mac), but I think this would make a good feature, so I added it to the backlog.
                      VectorStyler @VectorStyler
                      This post is deleted!
                        @freggern This problem should be fixed in build 1.1.048
