    File drag and drop not working on windows 10
    13 Posts 2 Posters 12.5k Views 2 Watching
      freggern
      When I drag and drop a file form window explorer / window desktop to a vectorstyler blank window, VS open file tabs bar or a opened document, the dragged file will not open or add. Use VS 1.1.002 beta on windows 10.
      VectorStylerV 4 Replies Last reply Reply Quote 0
        VectorStyler @freggern
        @freggern This seems to be a regression in the new build. Will get fixed ASAP.
          @freggern This issue should be fixed in the latest build
            freggern
            • When no document is opened, drag and drop only will work if you realeased it in the middle area of the document area. There is a big spacing around this area without doing anything
            • When I drag and drop it to the tabs of the opened documents it don't will add the file as a new document or do anything.
              @freggern Yes it can be replicated, it seems that there is some issue with the margin (only a narrow margin at the bottom for me).
              I will keep this open.
                @freggern This problem should be fixed now.
                  freggern
                  The last two bugs where fixed before. I think there is a regression in this build you can't add Layers over the drag and drop function by using the layer panel. It will open a new document. I think in last releases it added a new layer with the svg file I dropped there.
                    @freggern I will try to replicate this on Windows.
                      @freggern I could not replicate this on Windows: if I drag a file over an open document canvas area, it will import the file content as a new object into the document.
                        freggern
                        I dont mean drop it at the document canvas area. I mean dropping it direct on the "layer panal"-area when a document is opened.
                          @freggern said in File drag and drop not working on windows 10:
                          Now I got it. Dropping files into the Layers panel is not yet supported (neither on Windows or Mac), but I think this would make a good feature, so I added it to the backlog.
                            VectorStyler @VectorStyler
                            This post is deleted!
                              @freggern This problem should be fixed in build 1.1.048
