HSL Sliders auto adjusting
I always use the HSL slider in design apps, since I think that's the easier way to adjust colors / saturation / lightness. There's something that could make this functionality better. In VS the L and S sliders won't auto adjust depending on the current settings:
http://cloud.movavi.com/show/3120a675-eab4-4bd1-998d-8c9821b20094
They will automatically adapt depending on the Hue settings though, but it would be very good if we would see an accurate color representation of the spectrums. Ie. when you drag the S slider, the L would adapt and vice versa.
@WhiteX This could be related to a bug with how the hue based sliders are displayed:
https://www.vectorstyler.com/forum/topic/1177/color-panel-slider-issues-part-1-hue-accuracyIt is the in the backlog.
Yeah, maybe. Thanks!
@WhiteX Should be fixed in build 1.1.002 beta
@vectoradmin Great, thanks! It works like a charm.
I reported this bug though, beware, it altered some drawings without me noticing it (and I saved):
- Unfortunately if you have selected an object with no fill and select CMYK instead of RGB then the fill is set to black and so on.
- If the color is RGB red and you select grey sliders the color is desaturated into a grey tone instead.
Selecting another display mode for the sliders shouldn't alter objects at all.
@Ingolf I keep this part open: changing color mode should not change on the object.
But the solution here will be an option. The main issue here is that in VS, changing the color mode also changes the fill color mode (fill / stroke colors also store the color mode).
There will be an option later to do or not to do this.
@Ingolf The option for applying or not the color mode is in the color panel menu: Select Color Mode
