    Auto select Name section in Save dialog box
    5 Posts 3 Posters 6.4k Views 2 Watching
      When "save" or "save-as" is prompted, could the wording in the document name area be pre-selected for easy name editing? Here is a video of what I am talking about. I have to go in and click and drag-select the "untitled" section before I can edit the name. Apple does this well when naming new folders and files.
      I would also assume this could be a system-wide improvement to anything that requires replacing filler text?
      b77B VectorStylerV 2 Replies Last reply Reply Quote 1
      • b77B Offline
        b77 @Boldline
        I also noticed this problem the other day — I think auto-select worked in past versions and somehow now it doesn't.
          Boldline @b77
          @b77 hmm maybe it was a regression.
            @Boldline It works on Mojave at least. I will check the others also.
              @vectoradmin I am switching over to an M1 Mac now using Monterey - that is where I'm currently seeing the issue. the restart of VS did not fix it FYI
