Auto select Name section in Save dialog box
When "save" or "save-as" is prompted, could the wording in the document name area be pre-selected for easy name editing? Here is a video of what I am talking about. I have to go in and click and drag-select the "untitled" section before I can edit the name. Apple does this well when naming new folders and files.
I would also assume this could be a system-wide improvement to anything that requires replacing filler text? -
I also noticed this problem the other day — I think auto-select worked in past versions and somehow now it doesn't.
@b77 hmm maybe it was a regression.
@Boldline It works on Mojave at least. I will check the others also.
@vectoradmin I am switching over to an M1 Mac now using Monterey - that is where I'm currently seeing the issue. the restart of VS did not fix it FYI
