Can it be exported to eps10?
Can it be exported to eps10? I want to submit it to microstock website but they need eps version 10 vector file.
@POKPAK101 It has EPS export (EPSF-3.0 according to the latest DSC spec, that is quite old).
The latest Illustrator CC also exports to EPSF-3.0. The main difference between the AI and VS exported EPS files is the postscript prolog code (which may matter for some sites).
Is EPS 10 exported by Illustrator 10? If so then it is the same.
I recommend trying out with the trial, to check if the exported EPS files are suitable for microstock.
If not, could you point us to their requirements.
Most microstock sites require an EPS file that is compatible with Illustrator version 10.
This is the requirements they want.
Vecteezy: https://eezycontributors.zendesk.com/hc/en-us/articles/360050217012
@POKPAK101 It looks like the VS exported EPS header is marked as EPS 8 (thanks @b77 for pointing this out).
I will open a bug on this one, I don't think it is a big issue.
