Mouse wheel & field value : integer value without decimal ?
Sorry if this has already been asked (or if the solution is in the doc). I checked in the preferences and couldn't find it but there are so many features.
The mouse wheel allows us to change the value of a field when the mouse is over it but is it possible to make the number change from an integer value without a decimal? and is it possible to use the modifier keys to change with a different magnitude (1 unit, 10 unit)?
@PatrickM No such option for scrolling with the mouse wheel in number editors.
Should this be added?
Yes please if it is possible (it would be very nice indeed
). I always prefer to change the size or position of objects by integer values and I always use this feature in other apps (e.g., Affinity). It saves a lot of time; I hardly enter any values in the fields now.
Thanks,
Patrick
would like this option too, is often so much more comfortable
to change the value this way, than by hand.
@vectoradmin I would also like some control over the mouse wheel zoom. It works fine but the zoom steps are a bit big, so some sort of control over the jump increment from preferences would be awesome.
This is what I implicitly mention by using modifier keys (shift - ctrl - alt): a magnitude of 0.1, a magnitude of 1 and a magnitude of 10 for example (whatever the unit, px, mm, cm inches), sorry if it was not clear.
Also, it would be brilliant if the magnitudes could be adjusted in the preferences (0.05 or 0.1 ; 1 or 2 ; 10 or 20, etc.)...
@Ingolf There is a zooming and panning speed in the Preferences -> Document Editor
@PatrickM The number editor scrolling magnitudes and zooming speed are two different things. Zooming speed is customizable.
I will add the number editor scrolling to the next build.
@vectoradmin Oh, brilliant!
@vectoradmin said in Mouse wheel & field value : integer value without decimal ?:
I will add the number editor scrolling to the next build.@vectoradmin Of course... "zoom", I read too quickly and was influenced by the topic of the thread.
Next build... amazing !
