Warp - Arc (Multi line text) not warping correctly
Using Arc (Lower) in this case. The second line warps as expected. The first line doesn't. I tried creating a background (white box) centering the text in the box, grouping the two and then warping the box and the text. That didn't help.
Example text:
Tsokolate
ang buhay ko!Tagalog (Philippines):
"Cocoa is my life!"
@fewerjunk said in Warp - Arc (Multi line text) not warping correctly:
I tried with Arc Lower and then with Arc and Arching, maybe these are more suitable.
Not sure exactly what is expected, can you give an example what is wrong with the first line?
(in Arc Lower the upper part will not bend as much).
@fewerjunk It works here, with or without a box grouped with the text objects:
https://recordit.co/lpR4e54PXb
http://recordit.co/BLfVRUSzxc
@b77 if you look at the top curvature of the tsokolate compared to the ang buhay ko you’ll notice they’re not the same which is the same problem I was having.
(I want them both to have the same curvature. Does that mean I have to warp each line separately rather than together? Or is there a different, better way to go about it with that in mind?)
@b77 said in Warp - Arc (Multi line text) not warping correctly:
Figured it out: Arching Warp is the way to go. That way I can control the warp (even multi-line) top and bottom. Arching lower is behaving as expected and only warping the lower of two lines, which isn't what I'm trying to do.
