    [Image Effect Window] Angle slider is scaled from -360 to 360deg.
    9 Posts 5 Posters 8.4k Views 4 Watching
      encart
      I'm not sure if it is present in all of the Angle sliders or only this one.
      Suggestion for improvements to the interface in the future.
      The sliders are a universal UI elements, but in the case of angles are not very intuitive. Maybe a circular slider or some kind of knob would be better.
      Windows 11 Home 10.0.22621
        VectorStyler @encart
        @encart I did try a circular slider, but I find it either uncomfortable or taking up too much space (of course it looks nicer).
          @encart About allowing negative angles: I did consider this originally, and (besides the longer slide interval) I think it is much easier to set -45 to get a downward 45 degree angle, than computing.
            b77 @VectorStyler
            @vectoradmin I agree with @encart that a circular slider for Angle is the best — it shows the angle visually, at a glance, as opposed to the linear one.
            What is the uncomfortable part, if I may ask?
              encart
              @vectoradmin I have nothing to negatives values, but from -360 to 360 is 720deg - 2 x full angle. Shouldn't be in -180/180 range?
              Edit:
              Sorry, I already know what you meant.
              I still have the impression that these are the problems caused by the lack of a circular slider with scale and snapping. When looking at such a slider, you immediately get clear information.
                Throwing an idea out there - what about a small preview of the angle as a line next to the slider? So as you adjust the slider, the line shifts accordingly, giving you the slider for control and the line for a visual?
                  @Boldline If you would do a quick mockup of your idea it would help us understand it better.
                    The Affinity model with a circular clock-like slider and a numeric field in the middle is very elegant and small too.
                      @b77 said in [Image Effect Window] Angle slider is scaled from -360 to 360deg.:
                      My mock up skills are not on your level @b77 , but this is what I was envisioning:
