Q/FR: Split a Shape into Different Shapes
  • Hi,
    Still experiment with VectorStyler,
    Is there a tool which allows to split a shape into different shape ?
    I can see a scissor tool, a razor tool etc, but none seems to create two shapes.
    Use case: split a cricle into two different semi circles, for eg.
    Maybe there is a workflow involving splitting path at certain point and make new section after? If yes, A gif demo will be welcome 🙂
    Thx!
    @X-Raym Yes, there are multiple tools and ways to do this:
    One simple example here uses Exclude of a line from the ellipse:
    https://recordit.co/ud5dr3DVQL
    (for some reason the menu on Mac is not shown in the recording).
    Of course, the knife tool works also: https://recordit.co/zh9qqQgIoJ
    (if Control is held, after the mouse is pressed, the knife tool cuts with a line).
    In both cases a "Object -> Break Apart" is needed to separate the resulting composite shape.
    There is also a shape builder tool, for more complex cases.
    And the trim and join tool can be used to cut / intersect shapes.
  • @vectoradmin
    This was the missing step in what I was testing, thx!
    I don't understand how to use this tool, it produces no effect apart from the red line.
    But I just found the path panel, I can see I can split path form there, with the Shape Editor Tool which allows to select points on paths.
    @X-Raym Trim and join is a bit different (it is not for cutting shapes), but it is a very good shape construction tool.
    Here, I have four separate paths (drawn with the Pencil tool), that are trimmed and joined:
    https://recordit.co/98sdrTfYNo
  • I can see various use case for this, interesting! Thx for the video demo!
