    Adding noise to a colour in a simple way
    18 Posts 7 Posters 15.2k Views 7 Watching
      VectorStyler @B-Vs-V
      @PatrickM It is possible, a bit more steps than AD:
      Open the Panels -> Effects -> Image Effects panel and add the Pixelate -> White Noise effect.
      Click on the arrow next to the effect name to adjust effect options:
      This is plain white noise. There is also a selection of procedural noise types (Perlin, Musgrave, Turbulence, etc) using the Generate -> Noise filter.
      I will investigate if other noise types (random, but not white) are feasible.
      IngolfI B 2 Replies Last reply Reply Quote 2
        Almost unusable from MP4 compression - but this is how I add noise to steps in a gradient in Affinity:
        Horrible video
        A bit of blur after can really make the grain look better.
          Ingolf @VectorStyler
          With some easy and quick access to noise from a color selector and different types of grain, it would be fantastic.
          Please note that adding it to only some gradient steps is vital; it is normal to add grain to the shadow/darker area of the gradient.
          There is grainspiration out there 🙂
          Film grain
          • B Offline
            B-Vs-V @VectorStyler
            @vectoradmin said in Adding noise to a colour in a simple way:
            @vectoradmin Thanks again. I may have found a bug: I could not disable the effect by clicking on the icon.
            • B Offline
              B-Vs-V
              @vectoradmin another point I don't understand: I would like to mask the effect of the noise/grain on one side of the object and I try to use the gradient mask but all the noise disappears. What am I doing wrong? And how do I edit the mask after creating it?
              thanks
                b77
                @PatrickM I can disable (hide) the effect here on the Mac by clicking the 'eye' button.
                But the gradient used as mask for the effect doesn't work in this case. It was working, IIRC. Looks like a bug.
                You can edit the gradient used for masking the noise effect by selecting it again from the Opacity menu.
                  @PatrickM said in Adding noise to a colour in a simple way:
                  Tried (both on Windows and on Mac) but could not replicate this issue.
                    @b77 There seems to a bug (or more) here. This one can be replicated on Windows.
                    Nevertheless, the mask is edited by selecting "Gradient" again from the drop down.
                    • J Offline
                      Jono
                      Whilst looking at the noise image effect, I have a small observation: When the value of angle and offset are increased, the value no longer displays correctly. In this screenshot the angle should show a three digit number.
                        VectorStyler @Jono
                        @Jono said in Adding noise to a colour in a simple way:
                        It looks like the Angle value is clipped, and needs a larger field.
                        • B Offline
                          @vectoradmin no way to hide the effect on my side. When I click elsewhere and then select the object, the effect is well enable. Do I send you the file by email?
                            @PatrickM Please send me the file by email.
                            • B Offline
                              @vectoradmin Ok, I found the issue. It's fine when the panel is free:
                              but the issue is there when the panel is docked:
                              • ZATOPEKZ Offline
                                ZATOPEK
                                Hello
                                I’ve tried lots of tests to match the AD noise with VS, but without success. What I get is more fine with VT. Would it be possible to have more big noise like AD?THINKTANK 2026-03-27 à 21.56.52_1.jpg THINKTANK 2026-03-27 à 21.57.45_1.jpg
                                Cordialement Votre
                                VectorStylerV E 2 Replies Last reply Reply Quote 1
                                  VectorStyler @ZATOPEK
                                  @ZATOPEK In. the "White Noise" image effect you can adjust the Amount and Limit fields, (increase Amount and decrease the Limit) to get stronger noise.
                                  • E Offline
                                    EricP @ZATOPEK
                                    @ZATOPEK a couple things to consider when comparing noise effects :
                                    • Affinity adds a white noise on a pixel basis (each pixel value seem independent of its neighbours), it is not a grain effect or 2D noise where neighboring pixels would have correlated values.
                                    • document size in pixel will influence greatly the size of the noise "particles". A smaller document will have bigger noise particle size in relation to vector shape, than the same noise applied to the same shape on a higher resolution document
                                    • Affinity rendering engine is very well optimized for fast rendering of multiple layers and uses dynamic image resampling based on display zoom. So, relative noise size will change as you zoom in and out. This can confuse you in thinking you have large noise grains at low zoom settings. But when you zoom in, you see the noise gets smaller and smaller
                                    • same goes for exporting. If you export at low resolution, you will get large noise grains. If you export at higher resolution, you will get smaller noise grains. Noise grains are one pixel always
                                    • a way to get a more accurate view in both AD and VS is to switch from vector to pixel view mode. You will avoid the display oversampling at high zoom settings.
                                    AD's noise in color chooser is smart and very easy to use, but it lacks configurability.
                                    On the other hand VS White Noise image effect is less immediate, but offers much more configurability (experiment with different noise types - random parameter, limit, amount, blend type ...) and you can get all sorts of variations.
                                    On SVG export, both AD and VS need to rasterize the noise into a clipping mask as noise is not a standard SVG attribute.
