    Excessively large VS files
    5 Posts 3 Posters 5.8k Views 2 Watching
      I have what should be a very basic simple vectorstyler file that weighs in at 43mb in size.... I have two layers - one with an imported jpeg image that is 3.7mb in size. the other layer has a few lines of live text.... any ideas what would cause the excessive size?
        @Boldline Bitmap images (JPEGs, PNGs, etc) are saved internally in an uncompressed format.
        You can however compress the .vstyler file — File > Document Setup > File > Compression.
          @b77 said in Excessively large VS files:
          What does this do exactly? What is getting affected?
            @Boldline LZ77 compression is lossless and I think Zstandard is also lossless (developer can confirm), so no quality is lost for the bitmaps in the file.
              @Boldline Images are saved without compression in vstyler files. The vstyler file can be compressed (see @b77 comments), but there is an open task to have the images compressed separately regardless of vstyler document settings.
