    Mojikumi rules and symbols
    10 Posts 3 Posters 13.0k Views 3 Watching
    • A Offline
      ash-f
      These symbols usually have to be half width(spacing) by default in Japanese regardless of its position.
      VectorStylerV 861475_VctSt8 2 Replies Last reply Reply Quote 0
        VectorStyler @ash-f
        @ash-f I will try to fix this.
        A 3 Replies Last reply Reply Quote 1
        • A Offline
          ash-f @VectorStyler
          @vectoradmin Thanks. ask me if any question about it.
          • A Offline
            ash-f @VectorStyler
            Revision for the rules. my explanation was not proper.
            1. please add a Mojikumi preset that makes all symbols half width.(Yakumono Hankaku)
            2. please add a preset that uses the rules below
            • basically all symbols are normal width.
            • opening brackets(quotes) following another symbol or space have to be half width.
            • punctuations(、。,.) followed by a bracket(quote) have to be half width.
            • closing brackets(quotes) followed by a punctuation(、。,.) have to be half width.
            Regardless of which preset:
            These should be half width by default.
            P.S.
            Please forget about "symbol following another symbol shouldn't be half width."
            • A Offline
              ash-f @VectorStyler
              Also opening brackets(quotes) always have to be half width when they're at the start of the line.
              Paragraphs usually starting from a space(Japanese space which is double width) and if a opening bracket follows the space, it has to be half width.
              (actually opening brackets(quotes) following a space have to be half width regardless of its position.)
                VectorStyler @ash-f
                @ash-f said in Mojikumi rules and symbols:
                One question: are the half width rules apply when these characters are rotated for vertical typesetting?
                I will be back with more questions down the road (want to get this right).
                • A Offline
                  ash-f @VectorStyler
                  @vectoradmin Yes, it will be applied to both horizontal writing and vertical writing.
                  • 861475_VctSt8 Offline
                    861475_VctSt @ash-f
                    @ash-f
                    I have posted a proposal (f) for a future version. This is a pending project.
                    https://www.vectorstyler.com/forum/topic/480/cjk-japanese-observation-1-0-024
                    If ash-f understands Japanese, why don't we exchange ideas with each other before suggesting it to Vectoradmin?
                    Japanese character typesetting is based on a very complex set of rules.
                    The JIS X 4051 standard specified by the Japanese Industrial Standards is the basis for this.
                    English version
                    https://www.w3.org/TR/2009/NOTE-jlreq-20090604/#status
                    English-Japanese bilingual version
                    https://www.w3.org/TR/jlreq/
                    Japanese version
                    https://www.w3.org/TR/2009/NOTE-jlreq-20090604/ja/
                    However, now in the digital age, in Japan, each industry and each designer tends to make their own industry rules based on this regulation.
                    As I mentioned in my previous post, I don't think VS needs to deal with all of these, it should implement a minimum set of typographic rule patterns and leave the local rules to the users to customize.
                    I think the Mojikumi feature needs the following improvements
                    Show type preview in customize screen.
                    Import mojikumi data from InDesign, etc.
                    LIc. 0 OS10.15.7
                    LIc. 1 OS13.6.7
                      VectorStyler @861475_VctSt
                      @861475_VctSt @ash-f Some of the Japanese typography support issues are still open, including adding better defaults.
                        VectorStyler @ash-f
                        Is there a list of symbols that should be half width?
