Create Color Preset
Hello,
I can't find any sub-menu within Style menu to create the color preset. Can you help me?
Thank you.
Best Regards,
KF
@KF These are created from the Presets panel:
- open the Panels -> Presets -> Presets panel.
- select the object with the color to be saved.
- click on then (+) button in the panel.
- select Create Color
- set a name for the preset.
- the select object color is saved as a preset.
- the third icon of the panel can be used to edit the preset color.
Hello,
Thank you for the guides. I have create the color presets successfully. But accidentally I have closed the color presets within the preset panel and now I couldn't retrieve the color presets. I click Update and Synchronize Presets button but not works.
Thank you.
Best regards,
KF
@KF What probably happened is that the Color preset type group was closed (hidden).
Go to the Presets panel menu and select Reveal Hidden Presets.
Hello,
It's working now. Thanks a lot.
Best Regards,
KF
