    Best solution for breaking apart merge results
    28 Posts 4 Posters 60.0k Views 1 Watching
      @vectoradmin I'm not getting a better result with "separate path". I saw where it was added in build 53, "new action to separate a path into non-overlapping parts" Can you explain more what it is supposed to do? Should it be accomplishing what I am seeking in the video example (splitting a merged result into individual parts)?
        @Boldline Indeed, my second suggestion doesn't help if you want to color the small parts of the volleyball differently.
        But the first suggestion… did you try it? Breaking apart the volleyball should convert all the "holes" into solid, fillable objects.
        Once you paste them all inside the big round shape (or just leave them on top), you can color them differently, or even draw inside them after a double-click.
        @vectoradmin I searched the Documentation for 'Separate Path' to see what it does, but couldn't find anything.
          I did try it but the break apart option is grayed out when I have the volleyball selected and attempt to use "break apart". I'm all for any options that help improve my work flow so if I'm missing something please let me know
          You mentioned "Breaking apart the volleyball should convert all the "holes" into solid, fillable objects." - but does that work if the "holes" are literally empty to begin with?
            @Boldline Ungroup it first, convert any brush strokes with 'Expand Stroke', then I guess you should combine them all into one object with Union.
            Then try Break Apart.
              I know this is a new feature @vectoradmin added in the last few weeks so it would not be found in documentation just yet. I know it's addition relates to this very situation i shared here. I did find it listed in the Build 53 list of improvements; "new action to separate a path into non-overlapping parts"
              I had asked in this thread for a deeper explanation of use from @vectoradmin
                @Boldline If 'Separate Path' does what you need for this case (that is, after you ungroup, expand stroke, and combine them all with Union), please post the image and explanation here. πŸ™‚
                  @b77 Ungrouping did the trick! union was not available or accessible even, but that is because the volleyball was already one unified shape - no overlapping parts. But I understand the purpose for union in cases with multiple overlapping individual shapes.
                  "Break Apart" worked! I'd never considered "break apart" would result in solid fills where there was once no fill at all. That's fascinating! Thank you for sharing that. I'll be adding this to my workflow for sure.
                  It's great that it creates a fill where this was negative space - and I love the way "break apart" creates a solid backing fill behind everything.
                  Also interesting is that once I've created it using the break part method, if I select all including the backing solid fill and hit "merge" at that time, I get the individual parts I was initially wanting (individual shapes with no backing fill)
                  The only downside to using this method is literally everything becomes the same exact fill color and you have to go in and edit the colors piece by piece. Not a big deal on a simple design, but more cumbersome on others.
                  All that said, I still would like to see "separate path" be the tool that I was describing initially, as I believe it was added for. Having both options would be ideal in my mind as I would use them differently
                    I tried again with the volleyball and "ungrouped all" first - made sure it was all one shape (union was still not applicable here since it was always one shape). I tried "Separate Path" here at this point to see if it acted like "break apart", but it did nothing. I added the rectangle shape in the background and selected both and merged, then clicked on "separate path" and had no visible changes - the merged result was not broken up into separate parts. I don't know if there's a bug with "separate path" or I'm not using it correctly
                      @Boldline OK, so 'Separate Path' explodes any object made of separate paths into separate objects.
                      That's why it doesn't do anything in this case, except maybe it separates the unconnected thin brush strokes.
                        @b77 Is that any different than just "ungroup all"?
                          @Boldline Groups can be:
                          • individual objects grouped together;
                          • multiple groups that are grouped together;
                          • a mix of individual objects and groups grouped together.
                          'Ungroup' ungroups separate objects or groups that were grouped.
                          'Ungroup All' does successive ungrouping until any grouped groups are ungrouped.
                          'Separate Path' explodes one composite shape into separate objects.
                            encart
                            Another problem I faced. I haven't found the perfect solution. You usually have to do something manually. If there are any holes inside it becomes a mess . i have two paths for you.
                            1. Break Apart, then Divide and remove useless parts.
                              https://recordit.co/QwsCGQ3rOW
                              2.You could try Shapebuilder.
                              https://recordit.co/Vjlyyuyjxy
                              Sorry to post an AI link, but I get weird things out in our VS. I want to show you a possible solution to the problem Perhaps it will go better in your case on Mac.
                              I'm waiting for VS's Shapebuilder to handle complex shapes badly:)
                              b77
                              @encart Regarding the 1st video:
                              No app could figure out you don't need those three strokes and remove them automatically. πŸ™‚
                              You need to remove them manually before breaking the complex shape apart, so they won't leave holes in the bigger shapes.
                              (BoldLine's problem was being able to turn the "negative space" of the volleyball shape into fillable shapes. Any unconnected brush strokes in the volleyball are needed, I think).
                              Regarding the 2nd video:
                              I guess the app's Shapebuilder tool can be used to "disolve" those holes left from the unconnected strokes. Is that not working?
                                @b77 Thank you for breaking that down - that makes total sense now.
                                So "separate path" would be the solution if I had a compound shape/ if I used the combine boolean operation prior to make a compound shape
                                    Boldline @encart
                                    @encart I appreciate your input and your idea to use the "divide" function after "break apart" makes a lot of sense. I tried it out myself and it worked well for times I don't need the backing fill shape provided by "break apart" - ( though that could also just be clicked on and deleted). Hitting the divide "shows" me the different shapes and allows for easy selection and color change
                                    I also tried the Shapebuilder option on the mac in VS much like you did in Illustrator with mixed results. It reminds me a little of the "Live Paint" option in Illustrator and this would be a great addition to VS though I assume it's a 2.0 update. I'd even suggest the function of live paint in illustrator could just be part of the existing Shapebuilder in VS.
                                    @vectoradmin could the shapebuilder be improved to accomplish what @encart was trying to do with shapebuilder in his video as well as my attempt in my second video??
                                    I also saw there is a "shape paint tool" already in VS - though I need to try it out more. it wasn't working for me but it might be my lack of understanding it
                                      encart @Boldline
                                      @Boldline said in Best solution for breaking apart merge results:
                                      Select the object/objects before you switch for Shapebuilder tool.
                                        Boldline @encart
                                        @encart I had the same issues with Shapebuilder when I selected the shape first as when I did not....
                                          This is how quick and efficient the task can be done in Illustrator. After merging, you just ungroup and delete any excess you don't need
                                            @Boldline Just four steps here in VS: πŸ™‚
                                            • select the voleyball shape and the rectangle;
                                            • click the Combine button (the first one), or choose Combine (Object menu > Combine > Combine);
                                            • use Break Apart;
                                            • delete excess.
