Distributing nodes equally along a line.
Hi
If the Line flip, you could still reflip it.
See in my steps i mentioned above.And as I saw your video, the last segment of your Line seems to be
a curve. Change this segment, e.g. the whole line, to a "Straight Line"
first. Then the nodes should distribute properly.
@Subpath whaddayknow.... I went to try again, and got the notification for an update. Installed that, and then it worked (albeit with the flip). Such customer support!
(coincidence, I know
)The only thing I did different, though, was to click the straight line icon in the Path Panel, just to be sure.
Great that it works.
And, yes it seems it have to be a "Straight Line"It's also a good day for me, the update fixed a bug I mentioned.
Have fun being creative
@Gremriel Thanks
Just to be absolutely sure, I made one segment slightly curved, and although the nodes were distributed evenly, the operation kind of fails when the node that precedes the curved segment is not on the line anymore. But now I know what to look out for.
yes, every Segment has to be a straight Line,
then it works. It did not work on Segments
which are curves.
@Subpath It would be cool if at some point, it would work on a curved segment as well
Got a kind of workaround for that.
Its a function i know from CorelDraw and VS have this also.
Take a look at the Picture here.
The Nodes you set this way, will always be in the middle.
@Subpath @Boldline @Gremriel The issue with distributing nodes has been identified. If any of the selected nodes has a control node (not the end of a line), the distribution may fail.
Is this not also what I had written ?
That all segments must be a "straight line"
so that there are no control nodes in the line.
@Subpath said in Distributing nodes equally along a line.:
Yes, it is.
Good tips. I learn so much from going through these bug reports as they often mention tools and techniques I've not even thought about yet!
me too
