Text Tracking controlled by option and right or left arrow?
@vectoradmin For consistency, I think it would make sense to use Option + Up/Down Arrow for increasing and decreasing the leading (the space between rows of text).
@b77 said in Text Tracking controlled by option and right or left arrow?:
@Boldline and @vectoradmin I think it's a mistake there in 'Keyboard Shortcuts' — the shortcut is somehow different.
You think it was supposed to be option-left or right arrow all along?
I remember bringing this topic up a long time ago but had forgotten where it ended up then
The developer has to know that.
@Boldline @b77 @encart The Option + Left/Right arrow for tracking is in the default shortcuts for tracking change.
@b77 There is Option+Command+Up/Down for leading.
@vectoradmin Option-Command + Up/Down Arrow doesn't do anything to text here. I also tried with Control-Option + Up/Down Arrow.
@b77 Only works when the text tool is active with selected text.
@vectoradmin What is the reason for having this limitation?
@b77 Option-Command + Up/Down Arrow shortcut is used for Object -> Arrange -> Bring to Front / Send to Back in selection mode.
Command + Up/Down is used for Forward / Backward arrangement.
Then why not have Option (Alt) + Up/Down Arrow for changing the row spacing, no matter the mode you are in (just select the text and it should work), just as Option + Left/Right Arrow works for tracking? Is there any conflict here?
@b77 That does the scaling now. (nudging the selected object size with the keyboard)
Text objects are special because fonts are involved — is this vertical s̶c̶a̶l̶i̶n̶g̶ distorting of fonts really useful and often needed? I would just drag the top or bottom handle if I wanted that (but 99% of the time I don't).
I would go for consistent shortcuts (Option + Arrows, or something else) for both tracking and leading and make them work also when you're not in text editing mode. That would be a fast workflow in my opinion.
