    Text Tracking controlled by option and right or left arrow?
    23 Posts 4 Posters 45.8k Views 1 Watching
      encart @Boldline
      @Boldline I'am not sure , but you can make it by pressing ALT+ Arrow. I'm not sure if it's default shortcut or created . You should check. I'm working often with tracking and assigned tracking to mouse roll profile (X-mouse button control app)
        b77 @encart
        @encart Yes, it works with Option-Arrow! Thanks! πŸ™‚
        encartE BoldlineB 2 Replies Last reply Reply Quote 1
          encart @b77
          @b77 Have you ever tried pressing the spacebar without releasing the mouse button when creating a node? ☺ https://recordit.co/CNBuWspbp7
            @b77 @encart I went into my keyboard preferences and found it! For me it's default shortcut is control-alt-. This is one I will modify the shortcut to for sure
              @encart Nice option. πŸ‘ I might have stumbled over it but I forgot (I kinda prefer to use the Path Sketch tool tbh). πŸ™‚
              @vectoradmin When holding the spacebar as @encart describes above, the node doesn't snap to another node when 'Snap to Points is enabled, so this nice feature is a bit limited.
              @Boldline and @vectoradmin I think it's a mistake there in 'Keyboard Shortcuts' β€” the shortcut is somehow different.
                Boldline @encart
                @encart It's a lot like holding down the command/control key while using the pen tool - allows you to modify the node placement and handles
                  @vectoradmin For consistency, I think it would make sense to use Option + Up/Down Arrow for increasing and decreasing the leading (the space between rows of text).
                    @b77 said in Text Tracking controlled by option and right or left arrow?:
                    You think it was supposed to be option-left or right arrow all along?
                    I remember bringing this topic up a long time ago but had forgotten where it ended up then
                      The developer has to know that.
                        @Boldline @b77 @encart The Option + Left/Right arrow for tracking is in the default shortcuts for tracking change.
                          VectorStyler @b77
                          @b77 There is Option+Command+Up/Down for leading.
                            b77 @VectorStyler
                            @vectoradmin Option-Command + Up/Down Arrow doesn't do anything to text here. I also tried with Control-Option + Up/Down Arrow.
                              VectorStyler @b77
                              @b77 Only works when the text tool is active with selected text.
                                b77
                                @vectoradmin What is the reason for having this limitation?
                                  VectorStyler @b77
                                  @b77 Option-Command + Up/Down Arrow shortcut is used for Object -> Arrange -> Bring to Front / Send to Back in selection mode.
                                  Command + Up/Down is used for Forward / Backward arrangement.
                                    b77 @VectorStyler
                                    Then why not have Option (Alt) + Up/Down Arrow for changing the row spacing, no matter the mode you are in (just select the text and it should work), just as Option + Left/Right Arrow works for tracking? Is there any conflict here?
                                      VectorStyler @b77
                                      @b77 That does the scaling now. (nudging the selected object size with the keyboard)
                                        b77 @VectorStyler
                                        Text objects are special because fonts are involved β€” is this vertical sΜΆcΜΆaΜΆlΜΆiΜΆnΜΆgΜΆ distorting of fonts really useful and often needed? I would just drag the top or bottom handle if I wanted that (but 99% of the time I don't).
                                        I would go for consistent shortcuts (Option + Arrows, or something else) for both tracking and leading and make them work also when you're not in text editing mode. That would be a fast workflow in my opinion.
