    Detail optimizations for version 1.4
    18 Posts 2 Posters 112 Views 2 Watching
      VectorStyler @monsterfox
      @monsterfox These resource names are not translated for now.
      • M Online
        monsterfox @VectorStyler
        @VectorStyler https://youtu.be/RUzexgDw_Kc
        The red shape below is a group. I want one of its nodes to align, while keeping the group intact, to a node on the black shape above. I can’t get this to work no matter what I try. Could you add support for this operation?
          @monsterfox said in Detail optimizations for version 1.4:
          I will try to improve this
          M 4 Replies Last reply Reply Quote 0
          • M Online
            The panel translation for this tool is incorrect. It should match the menu: 自由渐变
            • M Online
              @VectorStyler https://youtu.be/wgPDmHoGeks ff41e68b-82bc-4c4c-bd4a-931afc5680fc-image.png
              ere are too many separate panels related to fonts. Could the frequently used ones be grouped together, similar to FreeHand’s panel sets? At minimum, combine these four (Font, Character, Glyph, Paragraph) into a single panel for easier access.
              • M Online
                @VectorStyler https://youtu.be/ED0mRNJZFMQ
                While drawing anchor points or dragging handles with the Pen Tool, you can hold Ctrl to move the current anchor point as long as the mouse button is not released. This feature needs to be added.
                • M Online
                  The node alignment feature with the "Sticky Groups" option works wonderfully after the fix. Just wondering if this operation can also be used for my case below. The three red squares are grouped. I select node 1 and then node 2 as the key objects. Would it be possible for the group to align relative to these two points when I click align? If this can be supported, it would be perfect. It would remove the limitation where I can only align compound paths from the Path panel.
                    @monsterfox When these two nodes are selected, what is the key object for alignment (to what are these aligned to)?
                    • M Online
                      @VectorStyler What I mean is to set the second point as the reference, and align the first node to it. My purpose is to make this group horizontal or vertical (using this like a rotate tool). I feel this should theoretically be supported.
                      • M Online
                        https://youtu.be/VBxToYiBZBg
                        1: When not in group state, an X appears when the mouse hovers over a node.
                        2: When a group is selected, an X appears on hover over a node to indicate that the node position is selected (there is a vertical line here, and the X shows up whether selected or not).
                        3: Only when no group is selected, hovering over square nodes does not show an X.
                        Could you fix this so the node X is selectable in all states? The object center axis also shows an X (the object pivot point, that blue dot).
                          This cannot be done with align. A new feature will be needed.
                            Will do so.
                            • M Online
                              https://youtu.be/sekdSJQtJ7o
                              1. When using the Mirror Group tool, rotating the object on the right displays the bounding box of the object on the left (this display should be disabled).
                              2. Does the entire mirror group moving along when the control object is moved count as a bug? If not, a lock function should be implemented for mirror groups.:
                                (1. Moving the control object moves the entire mirror group)
                                (2. Moving the control object does not move the whole mirror group; the mirrored object moves synchronously in mirror fashion as the control object moves)
