    Transformed Pattern option not working outside of Pattern panel
    8 Posts 2 Posters 46 Views 2 Watching
    • L Offline
      Li Xiao
      Only the 'Transformed Pattern' option in the Pattern panel works; the same option in the Properties panel, Context panel, and Appearance panel is ineffective
      L VectorStylerV 2 Replies Last reply Reply Quote 1
      • L Offline
        Li Xiao @Li Xiao
        @vectorstyler The 'Transform Noise' option does not work across all panels
          VectorStyler @Li Xiao
          @Li-Xiao These are bugs, I will try to fix them
          L 3 Replies Last reply Reply Quote 1
          • L Offline
            Li Xiao @VectorStyler
            @VectorStyler 'Transformed Pattern' is completely fixed now. However, 'Transform Noise' is still not working.
            • L Offline
              After testing version 1.3.032, 'Transform Noise' is broken across all panels.
              • L Offline
                Found a new bug with Pattern fills in version 1.3.032, except for the Pattern panel which still works, using any of the other panels (Properties panel, Context panel, Appearance panel) causes a crash. Version 1.3.031 had no issues.
                  @Li-Xiao said in Transformed Pattern option not working outside of Pattern panel:
                  I will try to replicate and fix this.
                    This kis not really a bug, the problem is that transform nose is not working with default noise options. You have to edit the Noise properties and change the Positioning mode (top-right corner of the nose options view).
