Select>Outline> Variable Width Brushes not working?
Re: update 1.0.044
@vectoradmin said in update 1.0.044:
@Boldline yes, the Select -> Outline -> Variable Width Brushes will select brushes with variable width profiles (tapered included).
hmmm
I'm running into issues when I attempt this. Am I missing something?
I used a tapered brush - expanded strokes, converted to curves for good measure lol, ungrouped, and then did the select>outline>variable width brush and the pop up box told me nothing was applicable
@Boldline That works for finding the original brush, before expand or convert to curves.
@Boldline For example, you have a drawing with lots of these brush strokes (tapered, or just variable width from pressure sensitive tablet).
You want to find them so that you can expand and convert to curves.
That is when you use this select action.
