Frame Text rendering & shifting issues in Transform Group
There are two issues when applying the Transform Group feature to Frame Text:
The text disappears after applying the Transform Group, but it displays normally after running Expand Appearance.
However, after expanding the appearance, ungrouping the text causes it to shift positions.
Performance becomes extremely slow when using the Action Panel to run a Transform Group that contains text objects. Non-text objects perform normally.
@Li-Xiao I opened a bug on this and will try to fix it.
@VectorStyler In 1.3.021, the other issues are fixed, but this one is not fixed: The text disappears after applying the Transform Group.
@Li-Xiao I will try to fix that
@Li-Xiao said in Frame Text rendering & shifting issues in Transform Group:
This is a bit problematic for how the transform groups work, currently it is not possible to have frame text inside transform groups.
I will try to fix this in the future
