update 1.3.021
VectorStyler 1.3.021 release notes
- Improved up/down key handling in number fields inside the list viewing mode of effect lists
- Improved spot color importing from PDF files
- Improved performance of Merge operation
- Added shape preset selection dropdown to context panel for text shapes
- Added separate Overprint Fill and Overprint Stroke to the Object Options
- Added an option to block overprinting by white colors
- Added an selection action to select objects with white color and overprint enabled
- Automatically insert nodes to the distorted path in the Shape Bump effect
- Show current brush in Brush panel when no object is selected
- Keep vector content position fixed when adjusting clipping with the crop tool
- Double click opening of a text should not pan the view
- Highlight first font when searching for font names
- Default drop shadow effect to allow direct shape scaling
- Allow larger ranges in the Overlay shape effect
- Fixed an issue with overlay shape effect on closed shapes
- Fixed sa bug in the Expanded Stroke adjustment effect
- Fixed a bug in expanding repeaters with number variables
- Fixed a font scanning bug on Windows
- Fixed a bug in the crop tool
- Fixed a bug in grading loading from Adobe Illustrator files
- Fixed a bug in expanding spot colors on multiple selection
- Fixed a text frame issue with custom shaped frames
- Fixed a bug in snapping to recently moved object shapes
- Fixed a bug in the Extract Parts shape effect editor
- Fixed a bug with the Send into Current Layer command
- Fixed a bug in exporting stroke width opacity to PDF
- Fixed a bug that occurred when dragging images from one document to an other
