<?xml version="1.0" encoding="UTF-8"?><rss xmlns:dc="http://purl.org/dc/elements/1.1/" xmlns:content="http://purl.org/rss/1.0/modules/content/" xmlns:atom="http://www.w3.org/2005/Atom" version="2.0"><channel><title><![CDATA[update 1.3.021]]></title><description><![CDATA[<h3>VectorStyler 1.3.021 release notes</h3>
<li>Improved up/down key handling in number fields inside the list viewing mode of effect lists</li>
<li>Improved spot color importing from PDF files</li>
<li>Improved performance of Merge operation</li>
<li>Added shape preset selection dropdown to context panel for text shapes</li>
<li>Added separate Overprint Fill and Overprint Stroke to the Object Options</li>
<li>Added an option to block overprinting by white colors</li>
<li>Added an selection action to select objects with white color and overprint enabled</li>
<li>Automatically insert nodes to the distorted path in the Shape Bump effect</li>
<li>Show current brush in Brush panel when no object is selected</li>
<li>Keep vector content position fixed when adjusting clipping with the crop tool</li>
<li>Double click opening of a text should not pan the view</li>
<li>Highlight first font when searching for font names</li>
<li>Default drop shadow effect to allow direct shape scaling</li>
<li>Allow larger ranges in the Overlay shape effect</li>
<li>Fixed an issue with overlay shape effect on closed shapes</li>
<li>Fixed sa bug in the Expanded Stroke adjustment effect</li>
<li>Fixed a bug in expanding repeaters with number variables</li>
<li>Fixed a font scanning bug on Windows</li>
<li>Fixed a bug in the crop tool</li>
<li>Fixed a bug in grading loading from Adobe Illustrator files</li>
<li>Fixed a bug in expanding spot colors on multiple selection</li>
<li>Fixed a text frame issue with custom shaped frames</li>
<li>Fixed a bug in snapping to recently moved object shapes</li>
<li>Fixed a bug in the Extract Parts shape effect editor</li>
<li>Fixed a bug with the Send into Current Layer command</li>
<li>Fixed a bug in exporting stroke width opacity to PDF</li>
<li>Fixed a bug that occurred when dragging images from one document to an other</li>
]]></description><link>https://www.vectorstyler.com/forum/topic/5865/update-1.3.021</link><generator>RSS for Node</generator><lastBuildDate>Tue, 21 Jul 2026 17:33:45 GMT</lastBuildDate><atom:link href="https://www.vectorstyler.com/forum/topic/5865.rss" rel="self" type="application/rss+xml"/><pubDate>Mon, 20 Jul 2026 07:57:15 GMT</pubDate><ttl>60</ttl></channel></rss>
