    the following applications are using files which the installer must update (failed several times)
    3 Posts 2 Posters 18 Views 2 Watching
    • Clippy notesC Offline
      Clippy notes
      Clippy notesC 1 Reply Last reply Reply Quote 1
        Clippy notes @Clippy notes
        Solution: The installer couldn't update the files because VectorStyler was still running in the background, even though the application window was closed.
        Fix:
        Open Task Manager (Ctrl + Shift + Esc).
        Find VectorStyler.exe under the Processes tab.
        Right-click it and select End Task.
        Go back to the installer and click Try Again.
        After ending the background process, the installation completed successfully. Using Continue wasn't necessary and avoids having files replaced only after a reboot.
          VectorStyler @Clippy notes
          @Clippy-notes Yes, if it is running in the background this will cause this.
          It should not run if the window is closed
