    Right-click to copy or paste in the panel text field does not work
    12 Posts 3 Posters 74 Views 2 Watching
    • W Offline
      William Kansepa
      @VectorStyler thank you for update 1.3.020!
      However, this issue is still not resolved...
        VectorStyler @William Kansepa
        @William-Kansepa It might be that only works on the mac, I will open a bug for this.
          @William-Kansepa said in Right-click to copy or paste in the panel text field does not work:
          I tested this on windows, and when right clicking the field, the number is copied.
          • W Offline
            William Kansepa @VectorStyler
            @VectorStyler said in Right-click to copy or paste in the panel text field does not work:
            Here it's still a challenge for me... Maybe there's a setting which I am missing?
            Anyone else experiencing this?
              @William-Kansepa No settings is needed.
              In the number field, is there anything selected when you right click?
              (if nothing is selected, it should copy the whole text)
                @William-Kansepa
                Could also be a mouse / input device type issue.
                What kind of mouse you use for this?
                • W Offline
                  @William-Kansepa
                  I am using a simple HP mouse.
                  I am not facing this kind of challenge in other software...
                  • L Online
                    Li Xiao @William Kansepa
                    @William-Kansepa I tried it on two different PCs, and it works fine on both.
                    • W Offline
                      William Kansepa @Li Xiao
                      @Li-Xiao said in Right-click to copy or paste in the panel text field does not work:
                      @Li-Xiao, Thank you for your response. I think I will have to try another mouse and hopefully I will achieve the desired result.
                      • L Online
                        @William-Kansepa You're welcome! Could it be a settings issue? A while back, importing AI generated images made VS crash on two Win PCs, but Mac was totally fine. It went back to normal after I reset it to default settings.
