    Bug List for Version 1.3
    124 Posts 4 Posters 18.6k Views 4 Watching
      monsterfox @VectorStyler
      @VectorStyler No, both of my software are set to MM as the unit.
      https://youtu.be/QGbnutySYEo
        VectorStyler @monsterfox
        @monsterfox I will have to review the DXF format to see how the units are handled. I reopened this bug.
          @VectorStyler https://youtu.be/ZfK73KvZJkY
          The issue with importing DXF files has now been resolved. The only remaining problem is that when exporting to DXF, the size of the original geometry is incorrectly scaled up. This has been tested across multiple software versions, and the same result occurs every time.
            @monsterfox I will try to fix this
              @VectorStyler 2aa71e2f-fa48-41e3-9e2d-da9bed3cb17a-image.png Right-clicking the icon on the desktop and selecting "Properties" fails to open the file location. This needs to be fixed.
                @monsterfox Will be fixed
                  @VectorStyler 9e074e6b-1603-4066-bc30-35938648ee89-6a740e6ee28a5e5a0aa4f4d00cbf8166.png
                  My software uses default font size parameters, yet parts of text are incomplete and invisible. This issue occurs on both panels and menus, hoping to get it fixed.
                    @monsterfox I will open a bug on this
                      @VectorStyler https://www.youtube.com/watch?v=QYDHd0Qpy90
                      I want to convert shapes to curves. The operation succeeds when there is no underlying image, but fails if an image is present at the bottom. Oddly enough, I didn't select the image at all. Please fix this issue.
                      外观.vstyler
                        @monsterfox For this you need to use Expand Stroke
                          The default UI font should be Microsoft JhengHei UI when the Chinese language is selected.
                            @VectorStyler Yeah, it's a font issue. I can't even remember when I changed the font.
                              @VectorStyler https://youtu.be/FZuNl0duLVQ 外观-12.vstyler
                                @VectorStyler https://www.youtube.com/watch?v=qCaylAF87PM 外观.vstyler
                                  @monsterfox I opened a bug on this
                                    @VectorStyler https://youtu.be/fYY9CcHI3SY
                                    After mirroring a rotated rectangle, the resulting selection does not follow the rectangle shape. Hope this issue can be fixed.
                                      I will try to find a solution for this, but currently the reflect tool "flattens" existing transforms.
                                      The problem here is that the order of non-flattened transformations is scale + rotate, if a new scaling (mirroring is one) comes, then the previous scale+rotate must be flattened
                                        The gray one is the original custom shape, and the red one is the custom shape rotated by 90 degrees. If the red one is not converted to curves, both custom shapes will have identical forms.
                                          @monsterfox Is this something that occurs with the repeater?
                                          Send me the file that contains these shapes.
                                            @VectorStyler Sent to your email, please check
